What power supply to use when I charge makerbuino how many Amphs and Volts?
You can use any Smartphone charger with 5 Volt and at least 1 Ampere to charge your MAKERbuino. Maybe even 0.5 Ampere could be enough.
As @Bl4ckM4ch1n3 said, almost every USB charger will work.
5V is a standard for USB so you don’t have to worry about that
Thanks i charget makerbuino for first time and it worked perfetly fine
great!
If you need anything else, tell me!
