All ok
I have followed your guide step by step and it worked perfect.
The only change that i have done is to the bat file i removed the “python .” from the start and the “pause” from the end because the command shown error.
Thank you Frank
All ok
Thank you Frank
Tested and confirmed working great for me, too. I have but one note, along the same line as what @Petros mentioned: If you install python with all the options you specify, the command to call upon python in the flash.bat file should technically be called as py .\esptool.py … or allow file associations to take over and just call to .\esptool.py … directly. Making this one small modification was all that I needed to flash flawlessly. My barely modified test v99.0.6 was flashed and booted successfully.
Technically, the file association for .py files added by the chosen options in the python installer should negate the need for explicitly calling py but there’s no harm in calling it, as some Windows installations will still screw up the association in a Command Prompt (cmd).
That said, spare the batch python invocation, which may vary for others (maybe note that if python .\… fails, try py .\… or just .\esptool.py… instead), this was simple and to the point. Exactly what I was hoping to see. I vote that you fire up a new topic and write it up, @frankprindle! Then @robertCM can unpin this one and pin the new one…just include a link-back in the new topic to this one for discussion. Then maybe Robert can lock the pinned tutorial thread to keep it clean and leave this one open (maybe edit Title to add (discussion) while he’s at it) so we can answer questions.
Here is draft 2 of my instructions with the py issue addressed: Build Custom Ringo Firmware Draft 2.zip (47.1 KB)
Excellent! I think it’s great as it is now. Let @robertCM know as soon as you get it posted so he can lock it while it’s still pristine. haha
I’m not sure I see any reason to lock it. He can still pin it if he wants, but there is no reason there couldn’t be discussion after the main post, since any modifications/improvements over time would be incorporated into the zip file that will remain in the first post.
TWM… done and done.
I figured we could use this thread for discussion and keep the other new thread as a pinned comment-less tutorial post. That said, this is #NotMyCircus (Or, should I say, #NotMyCircuitMess
) Y’all can do it however you want.
Ok, Robert’s got it all set up and I redirected any discussion on the subject from that topic back to this one.
Yesterday 30/07/2021 by CircuitBlocks I did Restore OS and I am uploading version 1.0.2 there is already version 1.0.5 for which I can not upload version 10.0.5? I’m trying to update directly from the phone and there is a message that the OS is up to date and I can not update to version 1.0.5 , why?
I don’t have the phone but those look like AT commands for the SIM module.
Maybe SIM module debug option is turned on?
i just did a system restore and previously i had 1.0.5 and now it has uploaded 1.0.2. in version 1.0.5 there were no ringing bugs and in version 1.0.2 there is just such a bug.
System Restore reverts system max to version 1.0.2
@PostScriptum sorry for the slow reply here.
This was indeed an issue from our end, we’ve forgotten to update the firmware to the latest release.
We’ve pushed a fix now so the next time you open circuitblocks, it should automatically update. Press the restore firmware button after that and the latest version of the firmware will be loaded.
Thank you
