Spencer change voice
Hello.
Is there any way to change the Spencer’s voice ? for example Female ?
I have found this
“voice”: {
“languageCode”: “en-US”,
“name”: “en-US-Standard-D”,
“ssmlGender”: “NEUTRAL”
“audioConfig”: {
“audioEncoding”: “MP3”,
“speakingRate”: 0.96,
“pitch”: 5.5,
“sampleRateHertz”: 16000
Also when i compile the Spencer’s firmware ( with Arduino ) it shows too many warnings.
Except the warnings after the upload the Spencer is working ok.
Thank you
All current responses are pre generated files stored on Spencer. Take a look at sentences.sh
Changing speakingRate and pitch would change voice. TTS service used is Google speech.
So I suggest take a look for detailed voice and audioConfig options https://cloud.google.com/speech-to-text/
I was looking into speech recognition & speech support for other languages (also not supported by Google, so needed to replace STT service). But that’s out of the scope here.
Thank you for your answer.
Do you have compiler warnings too ?
First time I compiled using an Arduino IDE I got the following error. Next time the error was gone & was able to upload firmware. Using MacOS.
In file included from ~/Library/Arduino15/packages/cm/hardware/esp32/1.1.0/libraries/CircuitOS/src/Input/I2cExpander.h:2:0,
from ~/Library/Arduino15/packages/cm/hardware/esp32/1.1.0/libraries/CircuitOS/src/Input/I2cExpander.cpp:1:
~/Library/Arduino15/packages/cm/hardware/esp32/1.1.0/libraries/Wire/src/Wire.h: In member function ‘uint16_t I2cExpander::portRead()’:
~/Library/Arduino15/packages/cm/hardware/esp32/1.1.0/libraries/Wire/src/Wire.h:99:13: note: candidate 1: uint8_t TwoWire::requestFrom(int, int)
uint8_t requestFrom(int address, int size);
~/Library/Arduino15/packages/cm/hardware/esp32/1.1.0/libraries/Wire/src/Wire.h:97:13: note: candidate 2: uint8_t TwoWire::requestFrom(uint8_t, uint8_t)
uint8_t requestFrom(uint8_t address, uint8_t size);
