Hi, I have a Chatter 2.0 and wanted to test if it could host a Wi-Fi server. When I first uploaded the code, it worked, but after a few more uploads, the device disconnected from my PC. Now, when I turn it off and back on while connected to the PC, it briefly detects the device before disconnecting again. Is there a way to fix this? Also, is there a solution that doesn’t require spending money? (I used Arduino IDE for the code uploading)
Never mind, I figured it out.
If anyone else runs into this issue, here’s what I did:
- Run:
pip install esptool - Upgrade pip (I had to, but you might not need to).
- Run:
(Replaceesptool --port COM# chip_idCOM#with your actual port number.) - Quickly turn your Chatter off and back on while running the above command.
- Run:
esptool --port COM# erase_flash - Quickly turn your Chatter off and back on while running the above command.
This should help if you’re experiencing connection issues.
glad to hear you figured it out!
Thank you for sharing with the community!
