hi. which type of cable should i use to charge my makerbuino?
Hey, welcome to the forum!
Your buino is charged using a Micro USB type B cable.
this one is usually used for charging older Android phones.
You can find it on Amazon if you just search for a “micro usb cable”:
https://www.amazon.com/s?k=micro+usb&ref=nb_sb_noss_1
Hope this helps!
Thanks Albert for the information. Do i have to plug it into the Li-Po charger board?
Yes, that is correct
