Chatter 2.0 Restore Stock Firmware Question
Hey Team,
Just joined the CircuitMess community and had a question in regard to the stock firmware vs. development.
I just started playing around with the Chatter 2.0 and after following along with the initial tutorials I wanted to go back to the original firmware but the only solution that I can find so far is a restoration of the stock firmware. However, this not only clears the memory of any programming done, it also clears contacts, profile changes, etc. that were made initially.
Is there anyway around this or is this just the way the Chatter 2.0 is designed to function?
If there isn’t already a pre-programmed way, I was thinking that the stock firmware could be edited in Arduino outside of CircuitMess environment to exclude initial changes when clearing memory.
If not, that’s fine too! Thank you!
Hey @Rain,
thank you for your question.
Unfortunately, there is no way around this. To return to the previous firmware, you must restore it, and there is currently no way to maintain your account, contacts, and other information on your Chatter while doing so.
Thank you for your understanding,
