Chatter antenna and range
I just switched on my Chatter for the first time, but I noticed i cannot chat with a device in the next room. I am not really sure i soldered the antenna very well - is it possible that this is the problem, or is this normal?
Hello @Miglena_Georgieva,
Thank you for reaching out and we’re really sorry to hear that you have this issue.
Please check on both Chatter devices whether the antenna pin is properly connected to the PCB. If it’s not, we recommend re-soldering it carefully. Make sure the solder joint is solid but not excessive, as too much solder can cause connection issues.
Let us know how it goes and if you need further help!
Kind regards,
