Is there any physical difference between chatter and 2.0? I’m wondering if it’s possible to upgrade to 2.0 by flashing the newer firmware onto an original Chatter?
Hey @Batmangb,
thank you for your question.
The difference is in the design and in the building process.
Please don’t flash the firmware for Chatter 2.0 onto the original one.
Both versions can do pretty much the same things.
Hi Monika,
Thanks for your reply. I understand that they do much the same thing as each other, but crucially they are unable to communicate with each other. I have seen some custom firmware on here that will try.
Thanks
