Code compilation taking very long time (20+ min), seems to stop half way, already done reset to factory setting, still same problem.
Also a Java error code occurs after shutting down “Uncaucht exception. Error: object has been destroyed”
Hey @Gen,
Thank you for reaching out.
Unfortunately, the code compilation can take a little longer, especially if this is your first time running the code on your device.
Please run the code again, and when the error appears, click on the send error report button and send me the report ID.
