Hello
i discovered there is an error in the Light show tutorial.
During the first half of the tutorial you are using change by blocks instead of change to blocks, to set the value of the color variable. During the later part it seems you discovered the mistake and used the right Coding Block in the ScreenShots but didn’t mention it in the text. Could you please correct the tutorial?
bye
Kolia
