Hello.
Does anyone has the stl or another file format of the cases so i can cut new ones with laser ?
My front case is broken.
Thank you
Hello.
Thank you
If you need it for the makerbuino: https://www.circuitmess.com/wp-content/uploads/2020/02/MAKERbuino-CNC-casing.pdf
If for ringo phone then there is this: https://circuitmess.com/resources/creations/81
Hope this helps, if not someone else will know.
If you don’t have access to the necessary equipment to cut a new one, the Circuitmess team may be able to ship the piece(s) you need via inexpensive regular postal mail to you for little or no charge since they are so lightweight. Of course, I dare not speak for the CM team, so @robertCM or @albertgajsak would have to confirm this for you.
Yes it will be good. Because i have checked the files that RegularGuy told me and they have errors as my laser tech told me. The circular cuts are not spaced evenly.
Thank you for your answer. I will check them
No problem at all, we’ll happily send you some replacement parts for a very low fee.
What do you need exactly? The transparent one or colored one?
Hi Petros,
Here are links to the tinkercad designs I did last year, I think they should help you.
Cheers
Coyote
