me and my daughter just finished building the nibble i bought and after turning on nothing but blank white screen…
Hey @Jorden_N,
Can you please send us the photos of the front and the backside of Nibble so we can check where the problem might be?
Please send the photos to contact@circuitmess.com.
Thank you,
try reflashing/restoring the firmware on CircutBlocks and check the ribbon cable, it could be a hardware issue also click this link, it will give you a basic intro to ribbon cables
make sure there are no blobs, make sure you didn’t burn any of the pins, make sure your solder connected the pin to the board itself
Thank you for sending the photos.
You’ll need to fix some of the soldering joints.
This is the image that can help you with that:
Also, please check the following soldering tutorials:
- Adafruit’s video tutorial featuring Collin Cunningham
- Adafruit’s standard soldering tutorial
- Sparkfun’s video soldering tutorial
- Sparkfun’s standard soldering tutorial
We highlighted the soldering points that need fixing.
If you don’t manage to get your device to work, please contact me again, and I’ll help you further. ![]()
