Last year, i said i was making an online game, i have done the first step. i am hosting a website off of the nibble!
look at the following steps below to use.
open the file Nibble_Hosting
it says #define STASSID. in the “”, type your wifi name (also known as ssid)
it also says #define STAPSK do the same again with wifi password.
Run and open serial monitor at 1200 baud. it should look like this if you get it correct
the thing at 15:28:29 is nothing
the code:
codes i had to use this, the file uploader doesn’t work
