In circuit blocks you can make your own cusotom pixel and use them in code for JayD which is great but they have a mysterious bug that i cant quite solve. Using built in sprites works just as expected but the sprites i made get corrupted. Generally the pixels at the bottom row of the sprite will be corrupt with wierd blacks and whites and greys. The best solution i have found for it is to add extra unused space to the sprite but that will not remove the corruption, it will just make it so that the corruption isnt blocking your sprite. As i mentioned before, this doesn’t seem to affect builting sprite which confused me even more. The sprites i was using were 11x11 so is the size causing an issue maybe? Please tell me if you know whats going on here or if you need more information about the issue.
Hey @Cool_Guy,
you can try doing it again and send us a bug report (click on the little bug icon in CircuitBlocks). That way our software team will be able to see what’s going on in your code.
Thank you!
can you send photos, I also own a wheelson with inverted coloros and color bezzels on the corners
