When using CircuitBlocks, is it possible to keep the program in memory and have it started when the watch is powered on?
From my expirience with circuit blocks no. I have found that using a different ide like arduino will save the program on your device when its turned back on. I’ve nevered programmed a clockstar but i would asume that this remains true. I will note that it my be tricky the get it set up on a different software. Maybe someone knows a better alternative, but this is the best answer that i have for saving the sofware after turing it off. Ill be sure to check back in if i find anything helpfull :).
unfortunately we don’t have that feature available yet. However, we are working on it and it will available in the future! ![]()
