Launching micropython from SD card
Hello,
I have tryed the web based CircuitBlocks and I successfully run an example.
In order to do so the microptyhon environment gets installed on the Byteboi flash instead of the default firmware.
After that if I want to run the games that came with the SD card I have to restore the original firmware.
The whole process takes a lot of time.
My question is: is it possible to istall Micropython as an additional application on the SD card and avoid reflashing the firmware every time I switch from coding to playing games and vice-versa?
Hey @Senbei64,
thank you for your comment.
Unfortunately, MicroPyhton is more complex than the games, and it is not possible to put it on the SD card and change it like that.
Thank you for your understanding!
Use ThonnyIDE to reprogram and flash Micropython to the ESP32
