the LEDs of my ByteBoi work fine during the hardware test program, but they won’t do anything if I try to use them in my own programms or if I complete the tutorial.
I even tried to do a very simple program like the following:
Wouldn’t it be more helpfull to discuss it here?
Maybe the solution is also interesting to others.
I tried it now on 3 different PCs neither my code as shown above lets the LEDs glow nor the example code from CircuitBlocks. During the hardware test program the LEDs work just fine.
Maybe there is something missing in the genereted code of the setRGB LED color block?
Can you export this sketch binary and send us that file to check where the problem might be?
Also, it would be helpful if you could add a block into the “When button gets pressed” block so we can check if that part of the code is working properly.
Hello,
here is an export of my own program and of the one coming with circuitblocks.
I hope this will help us finding the problem.
I added a play tone block that works fine but still no LED. LED_Test_Example.7z (446.1 KB) KoliasCombinedColorAndLEDTest.7z (446.0 KB)
