Hi! Does anyone know what causes this or how to fix it? The only way i can see anything is by tilting the device, but i cant see from the top.
Hi, Yes I had the same issue and it was to do with the default contrast settings. Can you see anything at all when looking from the top of the screen?
I could see the following screen below…
If you press and hold button A for 2-3secs this will take you to the following screen…
Then press button A once… On Checkup Wizard. And you should then be at this screen below. Then press the Left/Right buttons to adjust the contrast and follow the on screen commands. Don’t forget to save the settings at the end.
