Bonsoir c’est quelle version actuellement du Ringo??? 1.0.2??? et comment rebooter le Ringo comme si qu’il sort d’usine?J’'ai tester Restor Ringo Firmware mais je me demande si il n’y a pas d’autre moyen de restor mon ringo comme si il sortait d’usine.Je suis trés novice en codage donc c’est de la decouverte pour moi d’ou ma demande d’une restoration du ringo sortie d’usine et l’historique et fichiers des version du logiciel qu’il a eu…voila
Merci d’avance.
Hello!
Yes, the current firmware is 1.0.2. It works a bit better and some of the features are fixed compared to the 1.0.0 version.
Restoring Ringo firmware will set it to the latest version. The only way you can bring it back to the original factory firmware is manually.
You can either do it by cloning some GitHub pages and building it yourself, but there is a much simpler way through Arduino IDE.
If you still haven’t, install Arduino IDE and Ringo library/board to it. Here is the tutorial on how to do this: https://github.com/CircuitMess/CircuitMess-Ringo-Arduino-packages.
Now, in Arduino Board Manager and Library Manager find Ringo files that are downloaded. There you will see that you can choose a version. While these file versions have a bit different numbers that the firmware versions, since they are not the same thing, reverting both of them to 1.0.0 should do the trick.
Not, just revert to the original firmware using Arduino Bootloader and you should have the first version on your phone!
If you get stuck somewhere, feel free to ask any questions.
c’est super merci a vous ,c’est bon pour moi, c’est vu et fait
