Yesterday I received and build my Ringo.
Everything ok except that it’s freezing: the time is updating every 3-4 seconds, button press ignored if pressed for less than 3 seconds, as you can immagine the Setup process was veeeery long. To unlock it I need to press # button for about 30-40 seconds… and so on…
Everything else is ok: display ok, sound ok, network ok, battery ok… Anyone can help? Thank you!
