The INT pin of the module
PCA9539 has some connection, could you help me, the connection is not there, can you help me, thanks
Hey there,
Thank you for your question.
This is the correct schematics; there are no connections on the INT pin.
Let us know if you have any further questions,
I don’t think it should be left floating. Tie it to ground or V+ depending on the sense of the input.
Based on the data sheet (page 12), I’d suggest: 47K Ohms to Vcc, and 100pF to ground.
