Not going past button test and rebooting
Hello! I got this and put it together and than i turned it on, did the button test and then it rebooted, no mater how many times I t rebooted, it wouldn’t work
Could you be more specific?
And try using circuitblocks to reflash the firmware
I turned it on, did the test button thing, and than it rebooted and no matter how many times I did it , it kept rebooting, all of the buttons were working correctly though
Just could be a firmware issue, just go to circuitblocks and reflash the firmware
On circuitblocks their is a button called restore firmware, press it and select byteboi, then plug it in WHILE ITS ON to your laptop/desktop and select the correct device and flash it
What is code blocks???
https://www.circuitmess.com/circuitblocks/
Can u send a video on the issue?
I’m charging my laptop, I’m going to try to see if it works tomorrow
Ok, If you can, can you send me a video and pictures of the solder?
I can’t my device doesn’t have a camera, my laptop does, but I need to charge it, check back tomorow
Alright, hope this helps
Thank you, I hope it does to
Check the batterie is plugged in right
also can u give me a video of what happens, and tell me if the led’s or speakers work?
Hey @Nicholas_Petrella,
Monika from CircuitMess here.
Can you please send me a few photos of your device (back and front, without the casings) to contact@circuitmess.com so our team can help you out?
Thank you!
