My byteboi won’t turn on can i fix it. And when pluged in only the charge light turns on i just got it today to
could be a ribbion cable problem, try checking the ribbon cable, it should look orange or yellow, if the cable is loose try to get it in all the way, if nothing works call circutmess custermer service to get a replacement screen, please tell if the speaker and LED’s do anything, also try going to CircuitBlocks and restore the firmware
Thanks I fixed it yesterday but am having trouble installing Micropython every time I try to install the it stalls and gets stuck do you know how I could fix it?
hope it helped,
and if it didn’t, get circuitmess customer support ![]()
Which file do i Use?
Hey @Abigail_Crowley,
if you are still having issues with installing MicroPython, please contact us at contact@circuitmess.com.
Thank you!
press the green code button then press download as .zip, then read the instructions
