hello,
i have just received the ringo phone, it works well. Now i’m trying to modify the firmware … but i have some errors while compiling …
i have followed the official tutorial, and this one.
but i always have the same erros …
Processing lolin32 (platform: espressif32; board: lolin32; framework: arduino)
------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/lolin32.html
PLATFORM: Espressif 32 (3.3.1) > WEMOS LOLIN32
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (esp-prog) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny,
tumpa)
PACKAGES:
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30100.210531 (3.1.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 29 compatible libraries
Scanning dependencies...
Dependency Graph
|-- <Ringo by CircuitMess Library> 1.0.5
| |-- <FS> 1.0
| |-- <Wire> 1.0.1
| |-- <SD(esp32)> 1.0.5
| | |-- <FS> 1.0
| | |-- <SPI> 1.0
| |-- <SPIFFS> 1.0
| | |-- <FS> 1.0
| |-- <SPI> 1.0
| |-- <EEPROM> 1.0.3
| |-- <HTTPClient> 1.2
| | |-- <WiFi> 1.0
| | |-- <WiFiClientSecure> 1.0
| | | |-- <WiFi> 1.0
| |-- <Update> 1.0
| |-- <WiFi> 1.0
| | |-- <WiFi> 1.0
Building in release mode
Compiling .pio\build\lolin32\src\main.cpp.o
Archiving .pio\build\lolin32\lib7a3\libSD.a
Archiving .pio\build\lolin32\lib043\libSPIFFS.a
Archiving .pio\build\lolin32\libaf3\libEEPROM.a
Compiling .pio\build\lolin32\libcd3\WiFi\ETH.cpp.o
Compiling .pio\build\lolin32\libcd3\WiFi\WiFi.cpp.o
Compiling .pio\build\lolin32\libcd3\WiFi\WiFiAP.cpp.o
Compiling .pio\build\lolin32\libcd3\WiFi\WiFiClient.cpp.o
Compiling .pio\build\lolin32\libcd3\WiFi\WiFiGeneric.cpp.o
Compiling .pio\build\lolin32\libcd3\WiFi\WiFiMulti.cpp.o
Compiling .pio\build\lolin32\libcd3\WiFi\WiFiSTA.cpp.o
In file included from C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\soc/soc/soc.h:20:0,
from C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\esp32/rom/ets_sys.h:21,
from C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\freertos/freertos/FreeRTOSConfig.h:120,
from C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\freertos/freertos/FreeRTOS.h:99,
from C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\cores\esp32/Arduino.h:32,
from src\main.cpp:1:
src\main.cpp: In function 'void setup()':
src\main.cpp:2201:42: error: 'EFUSE_BLK0_RDATA3_REG' was not declared in this scope
if(EEPROM.readBool(33) && REG_GET_FIELD(EFUSE_BLK0_RDATA3_REG, EFUSE_RD_BLK3_PART_RESERVE) == 1)
C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\esp32/esp_assert.h:29:38: note: in definition of macro 'TRY_STATIC_ASSERT'
if (__builtin_constant_p(CONDITION) && !(CONDITION)) { \
C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\soc/soc/soc.h:151:57: note: in expansion of macro 'IS_DPORT_REG'
#define ASSERT_IF_DPORT_REG(_r, OP) TRY_STATIC_ASSERT(!IS_DPORT_REG(_r), (Cannot use OP for DPORT registers use DPORT_##OP));
C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\soc/soc/soc.h:194:13: note: in expansion of macro 'ASSERT_IF_DPORT_REG'
ASSERT_IF_DPORT_REG((_r), REG_GET_FIELD); \
src\main.cpp:2201:28: note: in expansion of macro 'REG_GET_FIELD'
In file included from C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\lwip/arch/cc.h:39:0,
from C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\lwip/lwip/arch.h:48,
from C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\lwip/lwipopts.h:403,
from C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\lwip/lwip/opt.h:51,
from C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\lwip/lwip/ip_addr.h:40,
from C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\tcpip_adapter/tcpip_adapter.h:24,
from C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\esp32/esp_event_legacy.h:23,
from C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\esp_event/esp_event.h:26,
from C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\esp32/esp_event_loop.h:22,
from C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\libraries\WiFi\src/WiFiGeneric.h:27,
from C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\libraries\WiFi\src/WiFiSTA.h:28,
from C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\libraries\WiFi\src/WiFi.h:32,
from lib\MAKERphone\src/MAKERphone.h:58,
from src\main.h:4,
from src\main.cpp:2:
C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\newlib/assert.h:16:24: note: in definition of macro 'assert'
# define assert(__e) ((__e) ? (void)0 : __assert_func (__FILE__, __LINE__, \
C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\soc/soc/soc.h:151:38: note: in expansion of macro 'TRY_STATIC_ASSERT'
C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\soc/soc/soc.h:164:13: note: in expansion of macro 'ASSERT_IF_DPORT_REG'
ASSERT_IF_DPORT_REG((_r), REG_READ); \
C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\soc/soc/soc.h:195:15: note: in expansion of macro 'REG_READ'
((REG_READ(_r) >> (_f##_S)) & (_f##_V)); \
from src\main.h:4,
In file included from C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\esp32/rom/ets_sys.h:21:0,
C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\soc/soc/soc.h:165:37: note: in definition of macro 'REG_READ'
(*(volatile uint32_t *)(_r)); \
src\main.cpp:2201:65: error: 'EFUSE_RD_BLK3_PART_RESERVE_S' was not declared in this scope
C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\soc/soc/soc.h:195:32: note: in definition of macro 'REG_GET_FIELD'
src\main.cpp:2201:65: error: 'EFUSE_RD_BLK3_PART_RESERVE_V' was not declared in this scope
C:\Users\ewaca\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\soc/soc/soc.h:195:44: note: in definition of macro 'REG_GET_FIELD'
src\main.cpp:2201:96: error: invalid operands of types 'void' and 'int' to binary 'operator=='
*** [.pio\build\lolin32\src\main.cpp.o] Error 1
it seems to be due to ESP-IDF SDK difference between firmware and platformio.
can you help me plz ?
