Power switch issues?
uhm so, I broke my chatter 2.0s power switch… completely off. does anyone know if there’s any way to trick the chatter into thinking I turned it on??
Hi Reece_Bartos,
you can:
  1. replace the original switch with another equal
  2. replace the switch with a strip equipped with jumper
  3. short circuit the two lower contacts of the original switch
  4. make the modification described here Day 3- hacking Chatter2...frustrations - #5 by mog and power supply the device from its USB port.
  5. etc, etc…
Regards,
Fabrizio
