I have a problem with my Makerbuino.
In the morning, i put it on charging, but when i charged, it didn’t work.
Tin
Tin
Hi Tin!
Can you be a bit more specific? Did MAKERbuino work before or not?
What seems to be the problem now - is everything not working or just some parts?
Thanks,
Makerbuino worked before, and display light is active, but nothing else works.
Tin
@Tin_Radeljkovic0084
Hey, thank you for supporting MAKERbuino and I am sorry for the problems that you’re experiencing.
When you interrupt the loading process, the console’s memory will be blank so you have to do a hard reset like this:
insert the SD card
turn the console OFF
hold the C button
turn the console ON
release the C button
wait for 30 seconds
This was also mentioned in build guide’s chapter #4 (under the yellow section marked “IMPORTANT”)
https://www.makerbuino.com/build-4-some-more-soldering/
Keep us posted on your progress and don’t worry as we’ll help you make your MAKERbuino work
Albert
Thanks for reply, but it didn’t work. (After i did that)
Tin
I’m sorry to hear that.
Please, send us the console to our address:
CircuitMess,
Maksimilijana Vrhovca 11,
47000 Karlovac,
Croatia
We cannot help you remotely any further so I’ll personally fix your console and get it returned to you.
You only need to send us the circuit board in order to make the package as light as possible.
Thank you for your understanding.
I will send it tomorrow, but i will also keep the plastic cover on.
Thank you for fast reply.
Tin
Great, thank you very much!
