Radio frequencies in Japan
Greetings. I just set up my chatter 2.0, however I have found out that in Japan it might be illegal to use the Lorawan band in Japan? Can you confirm if this is correct?
According to sources provided, the 920 MHz band is used, but special requirements might be needed. It states as such:
  • 920 MHz Band (e.g., LoRa, IoT devices): This band is used for various data communication technologies, including LoRaWAN in some cases, but also requires certification and specific power output limits.
    Legal Requirements
  • Certification is Mandatory: Any radio transmitter used in Japan must have the GiTEki Mark (technical conformity certification). Using a foreign device that lacks this mark, even on a legal frequency, is a violation of the Radio Law.
Can you confirm that this Chatter 2.0 device is Giteki compliant and if so, where is the mark located on the device?
Thanks kindly.
Hello @Brossy ,
Thanks for reaching out.
The Chatter 2.0 is not GiTEKi certified.
Best regards,
Filip
