Hello, I have makerbuino for over a year now and it stopped working after a month having it, I tried a lot of things to try to fix the problem but nothing worked. I saw now that other people are having the same problem so I decided to come out to. So, when I turn the makerbuino on, the lights work, but the screen doesn’t. At first it worked a little when I re-inserted the sd card or when I did the C-button reset but just for a few seconds and then it blacked out again. I looked if there’s any bad soldering but there isn’t. Now the screen doesn’t work even when I do the C-button reset or when I re-insert the sd card. @albertgajsak what should I do?
