I noticed that the website http://simbuino4web.ppl-pilot.com/ is down. I sent back my makerbuino because of a screen issue so I can’t code anymore. I tried other emulators but none of them work properly (Android or Windows).
Could somebody help ? Maybe someone made a backup of the website.
Thanks,
Coralie
@Coco_Chix,
thank you for reporting this and I apologize for the inconvenience. The emulator was not hosted on our domain and/or server and we’ll fix that ASAP by setting it up on our server.
In the meantime, you can try this one:
I personally use this one and it should work fine on Windows but you have to install NET framework for it to work properly (follow the instructions).
I already tried to install Simbuino but it doesn’t work : the programm doesn’t start even if I installed NET framework .
It would be great if you host the emulator on your server. Please don’t hesitate to keep me up to date.
Hi people, I made a patched version of the web emulator that you can even run on your own pc: there is a bug in the code: https://github.com/Myndale/Simbuino/pull/3
Also added some other stuff for my own convenience…
