Hi
From time to time, the speaker goes dead and we can not listen to the conversation. The Mic remains working. A random number of restarts later it starts working again.
I worried about soldiering, but the speaker uses a preexisting connector.
Anybody having the same issue?
Roko
Have you tried wobbling the speaker wires and connector when it goes out? Could be a soldering problem where wires attach to speaker or where speaker connector attaches to main board. Also make sure the female plug is seated all the way into the male socket.
Less likely, if you have a 4G module, then it could also be a problem with soldering at the surface-mount components that are in the speaker circuit or the solder-jumpers also in that circuit. These components and jumpers are just below 4G module on the main board. There are also some surface-mount FETs up next to the speaker connector on either 4G or 2G boards.
Hey Roko,
Have you checked the connector? Since itβs at a very steep angle, it could be that the cable is a little bit damaged and that may cause connectivity issues from time to time.
Have you noticed any pattern? How often does it happen and does it stop working on the first call or not?
