We have just built our spencer and are using the tutorial to program. When we do the first step to program animation, when we click run it says "compile error. Check your code then try again. Is there also a page where we can download spencer code please?
Any help would be greatly appreciated.
Hi there,
Thank you for reaching out and for your support.
I’m so sorry to hear that you’re running into this issue.
Could you please send us an email at contact@circuitmess.com and we’ll help you out right away.
-Dorotea from CircuitMess
I am experiencing the same problem. This is the first attempt to upload a basic sketch (following the CircuitBlocks LED tutorial). The compilation bar gets to about 40% fairly quickly, then slows down considerable, and then I get the dialog that pops up and says:
“Running
Compile error. Check your code then try again.
Ok”
Is this perhaps some kind of permissions issue? I’m running on Windows.
Hi @kilter,
Thank you for reaching out.
We are sorry to hear you are experiencing some problems while trying to compile a code on Spencer.
Please, send us an email at contact@circuitmess.com, and we’ll help out immediately.
Monika from CircuitMess
