Spencer GPT voice commands after coding
Hi. We are using Spencer GPT and it works well. When we first plug it in, we can push the button and speak with it. When we start using CircuitBlocks, we can send commands to it not problem. The issue is that after we start sending commands with CircuitBlocks, we cannot figure out how to get the button to work again to force Spencer to start listening for GPT based commands. To get the voice commands back, we need to reset the firmware.
Thank you!
Hey @Christopher_Mina,
thank you for your comment.
Yes, you’ll have to do that every time you want to get back to the voice commands.
Thanks Monika.
I don’t suppose there are any workarounds you know of, for instance to code it back to listening for voice commands.
No, unfortunately, for now, we don’t have that option.
Apart from the gpt voice commands, it also seems impossible to control the speaker, for instance to synthesize words or listen to sounds via sketches. Once micropython is installed, it’s like that part of spencer is completely cut off, or does it only apply to the visual coding environment? Where can I find the list of functions (and their synthax) for the textual coding environment?
