Hey guys,
I’m a 3D Artist by trade but picked up a Nibble for my daughter and we’re building/coding it together.
I’m scoping out what’s possible right now and I’ve run into a bit of a wall with pixel sprites; how to load them and display them. Is there a way of doing this in blocks currently or will this need to happen in code?
I saw a post about how to do this for the phone kit but not sure if it applies here or if there are further resources.
Thanks!!
So after some digging, I think I need to convert any sprites we want to use to a byte array and reference it as a separate file ‘sprites.c’ in C++ and load in the sprite to use.
I found a web based tool on the forums to do it and a space invader example project. Might be a bit difficult getting my kids head around all that.
I think we’ll build the game out of prims in blocks, do the graphics together, then finally I’ll swap out the prims/do the implementation.
Thank you for supporting our work.
Yes, the sprite editor is on our to-do list.
I’ll see you around the forum
Ah that’s great. In the meantime I’ll figure it out in code and will do that manually.
Glad to hear that, please keep us posted
