okey so im going to attempt to recreate minecraft not like in 3d version but in ASCCI GRAPHICS or just normal sprites so it would have inventory health building
I found this āsimpleā C clone of Minecraft (MIT License). Itās targeted for Windows/OSX/Linux and uses OpenGL for rendering, but it might contain some valuable code and insights for a much simpler version that can run on Ringo. I bet the multiplayer aspects can be ripped right out to shrink the base single player code significantly.
As a fellow Minecraft lover, I look forward to trying this out when you have the first build ready!
the thing is with limited amount of memory and i dont know if the ringo board supports openGL i havent seen any game on ringo that is 3d or that uses openGL and if it requires 1mb of ram at minimum then it wont work perfectly
Oh yeah, this code would never be directly portable. However, even if you just reference/re-purpose the more ācommonā game functions/routines, like handlers for enemies, world block generation, etc, you could save yourself a lot of hassle versus trying to reinvent the wheel every step of the way. As far as ports/clones go, this was one of the simplest I could find already out there in the wild.
well im not thinking about it now bec im stuck at planning phase of my console i still dont know what type of cpu to use arduino or esp32 my last resort would be the rpi zero with the vulkan driver or the p8x32a-dip40 chip
Oh! Speaking of (and this may totally influence your decision hehe)ā¦have you seen this yet? Just came across my news feed yesterday.
You wonāt get nearly that performance on a zero, of course, but wow! I bet it would still perform well for your console project. Itās not the same as the open-source Vulkan project; itās specifically for Pi devices and written by an Nvidia engineer as a personal projectā¦spent 2 years on it!
yea im thinking to resort to rpi so i dont have to do more hassle
thewebmachine do you have a discord account ? :]
Sorryā¦been crazy busy working this week. I donāt mess with discord or most other social media, tho. I donāt even use Facebook. haha
oh well im switching to the hp compaq tc1100
Switching toā¦for??
With MMOs, the server often renders the complete processes, and the computer renders the local main object and remaining local available processes. It only processes what it needs locally.
Weāre only talking about two devices⦠plus, a lot less space is used. Minecraft is much bigger.
If the blocks are smaller, they could fit more than the mobile version.
I wonder if we could run a server for it though. It might have to run over LAN.
That might be the breaking point.
Even scaled down, 1mb is barely enough to build the images displayed on screenā¦
ASCCI is a good ideaā¦
You think so? I mean, the Ringoās small resolution means we donāt have to devote much to graphics, especially static objects. In fact, one would argue that, on a platform such as this, using a vector graphics engine might be ideal in both size and performance.
That is a very strange concept. I only had a small amount of training in visual arts. I donāt remember much about things like Vector vs Rasterā¦no hands on training with anything we do.
I can say thoughā¦by the maths, we can deduce all logical variables associated by screen size. It may be possible to cut corners and build simple short cuts. However, we must bear in mind our screen size. If for example, the screen weāre working with is a flat 400 screen size. That is close to our dimensions. We can easily divide 400 with binary fractions. 2^(any number) will equal any known square. 400 is divisible by a square. I am pretty sure we are going by 180x120 right now?
That is 21,600 pixels with individual 8bits.
(Notice - This example in general doesnāt really explain the Vector engine and I am simply pointing out the average logical calculation.)
21,600x8=172,800/1,000,000bits
The average Arduino sketch is about 20kb. 20,000/1,000,000
With a game example drawing from our (idk 1gb)storage folder on our 4gb storage card, we should be able to draw and place 20kb of main, 40kb of blocks, 40kb of characters, 40kb of items and get 140kb. 140,000 bits / 1,000,000 bits
172.8kb + 140kb is about .32mb/1mb
We can still render the program from the SD card.
We have .7mb left and we only need .3mb for performance tbh⦠another .3mb to be safe.
An example of what to emulate.
You canāt run a word processor on an Arduino with only 32kb. This article speculates what must be accomplished to build an eink Arduino word processing typewriter.
I chose this project because itās a simple illustration with pics vs a long page of physical research.
What I mean is that it shouldnāt be resized to fit our device.
It should be rewritten from scratch to fit Arduino.
It is possible with or without extra storage. We should do it ergonomically as possible. Minecraft has its own 1x1 dimensional blocks. That cube renders at a specific size - the screen size. So the screen of the device is irrelevant and also the game playing it. It runs on any JVM device.
Java -> Machine -> Device
The second build is a basic algorithm and architecture. An algorithm known as a random seed decides the environment most likely to appear. The nature of these blocks is placed around the center block. The last nature of the architecture is the location of the blocks. The location adheres after the known object has been rendered. The surrounding land is place within the decided depth with a predetermined height. You will see ground blocks < lava < diamond, so forth until ground blocks, tree objects < the sky, etc.
The first object to render is an object. The objects are trees/mobs/other land objects. The player is called onto a predetermined POV called DOF (depth). It tells the computer how much to process at once. With only 21.6kb, we should only see as far as a Minecraft house (desktop/laptop/tablet).
Any more than our immediate area should be placed onto storage.
Controls may resemble the Tamagotchi with a layout of Pokemon. However, we can have an options button. Looking around will be uncomfortable. We must see through the eyes of the Doom '93 player. Looking up or down by force. Crouching will be a chore. Hunters of diamond will be master arcade playersā¦
Game dev is far from my forte, so you probably have a much better understanding than I do of that concept. haha
As an asideā¦the IEEE Spectrum website is such a mess. Early 2000ās era full screen ad with āContinue to siteā button, menus and headers jitter around like a caffeine addict while scrolling, just a mess. For a body that develops standards, they sure do come up short on their own website. āPhysician heal thyself!ā
I donāt understand game dev tbh. Iām a very practical Roboticist.
Iāve heard and read about these guys who use triangles like ternaryā¦as if that makes sense.
Iām talking about using the individual pixels and forming squares to build objects.
We can mathematically build an object and then move it around on screen using coordinates.
I have never actually tried. Iām much less interested in the cyber world than some. Circuitmess is something like me. We prefer the circuit part for a crucial reason. 1 because proper training is important. 2 being able to apply that training. 3 adequately adapt that training in the future. You(being the qualified example) would not like it very much if you took āciviliansā on an exploration mission of the outer Sol system and take test liquid caps of Pluto. It would be a long journey with ādumbā people. They would be no actual help. I would expect Starfleet minimum.
Your profile says āSoftware Developerā? What do you do? I know a lot of people who write websites. It sounds expensive/annoying though. I had a friend who was so busy, he deleted his facebook to make up time for lost employees. He couldnāt pay them eventuallyā¦had a hard time finding clients.
Iām in the telecom space, so this was right up my alleyā¦tho I also very much enjoy tinkering with all sorts of things, including Bed Eaterās 6502 project.
I was re-reading this post recently and had a few follow-up thoughts/notes for ya:
- Screen size is actually 160x128px 16bit RGB and can operate between 25 and 50fps
- The controller Ringo is based on is dual-core 32-bit 160Mhz, 4MB EEPROM*** and a full 512kb of SRAM
- *** The 4MB flash EEPROM is partitioned using the min_spiffs scheme, which uses a dual OTA partition setup (this allows for the Ringo loader to actually load up apps, boot into the app, and then return to the Ringo loader later). Each OTA partition is 1,966,080 bytes in size
So, youāve got just under 2MB of flash to load the game engine and logic into, along with whatever media assets you donāt want to load from SD. Depending on the complexity of the game logic and related libraries, you might only have room for a splash screen in the bin. Loading from SD will certainly be slower, but having 512kb of RAM and dual cores does allow you to load assets into RAM behind the scenes - pinned to its own core, separate from the core the game is running logic/engine on - while playing the game.
My WiFiTest app is already at 1.4MB and Iāve only added two full screen static images (and a few very small sprites) as PROGMEM. Granted, a chunk of that is due to the MAKERphone library that needs included to most readily interact with the Ringo hardwareā¦unless you want to write all your own functions for accessing buttons/LCD/sound/etc and not be able to receive calls/SMS while in-game. This is why I suggest employing a vector engine. The storage needed to specify ādraw a line starting here and ending hereā is far less than ādraw this dot, now this dot, now this dot, now this dotā ad nauseamā¦vectors effectively compress the data needed to recreate the graphic (most of the time, anyway).
I get the mentality behind the Java approach to things, but have you ever taken a look at how much RAM a JVM can consume on a machine? Even lean JVMs have pretty hefty resource needs because itās an abstract virtualization layer in order to retain hardware agnosticism. Youād never get anything even close to a decent JVM running on this hardwareā¦at least not for a game (maybe a highly specialized app of some sort with a custom tiny JVM built around it, but youād likely still need to leverage the full 4MB EEPROM to fit it).
While Ringoās āNES controller-likeā button layout is ok for some games, I agree it would be less than ideal in a type of game like Minecraft/Doomā¦but we do have the full keypad available too. I image that you could use the joystick as āleft-handā movement and the keypad like a āright-handā D-Pad, allowing 8-way looking, with #5 to acting as a redundant A-Action button. You could have the keypad serve a second purpose at the same timeā¦press * or # followed by a number to select a weapon or item in your inventory, for example.
Or you could go all out, implement the Bluetooth library and allow for basic gamepad support. haha BT is surprisingly easy to work with, as it is a serial connection at its core.
