Arduino IDE fails to upload code on Clockstar 2.0
Hello! I want to upload persistent code to my Clockstar 2.0, but the Arduino IDE fails to upload code. As there is not an option for Clockstar 2.0, I just chose Clockstar. I’m wondering if the Clockstar 2.0 does not support the Arduino IDE. If so, is there another tool I can use to upload persistent code to my Clockstar? I will leave info about the error now, in case its helpful.
Fastfetch output:
OS: Manjaro Linux x86_64
Host: Precision 3520
Kernel: Linux 6.12.48-1-MANJARO
Uptime: 22 hours, 22 mins
Packages: 1359 (pacman)[stable]
Shell: zsh 5.9
Display (BOE06F1): 1600x900 in 16", 60 Hz [Built-in]
DE: KDE Plasma 6.3.6
WM: KWin (Wayland)
WM Theme: Breeze
Theme: Breeze (BreathDark) [Qt], Breeze-Dark [GTK2], Breeze [GTK3]
Icons: breeze [Qt], breeze [GTK2/3/4]
Font: Noto Sans (10pt) [Qt], Noto Sans (10pt) [GTK2/3/4]
Cursor: breeze (24px)
Terminal: konsole 25.8.1
Terminal Font: Hack Nerd Font Mono (11pt)
CPU: Intel(R) Core(TM) i7-6820HQ (8) @ 3.60 GHz
GPU 1: NVIDIA Quadro M620 Mobile [Discrete]
GPU 2: Intel HD Graphics 530 @ 1.05 GHz [Integrated]
Memory: 6.77 GiB / 31.23 GiB (22%)
Swap: Disabled
Disk (/): 88.26 GiB / 476.64 GiB (19%) - btrfs
Battery (DELL NY5PG98): 100% [AC Connected]
Locale: en_CA.UTF-8
Arduino IDE output (after clicking upload):
Sketch uses 193164 bytes (16%) of program storage space. Maximum is 1179648 bytes.
Global variables use 12680 bytes (3%) of dynamic memory, leaving 315000 bytes for local variables. Maximum is 327680 bytes.
esptool.py v3.0-dev
Serial port /dev/ttyACM2
Connecting...
WARNING: This chip doesn't appear to be a ESP32 (date codes 0x03700000:0x00000000). Probably it is unsupported by this version of esptool.
Chip is ESP32-D0WDQ6 (revision 0)
Features: WiFi, BT, Dual Core, Coding Scheme None
WARNING: Detected crystal freq 0.00MHz is quite different to normalized freq 26MHz. Unsupported crystal in use?
Crystal is 26MHz
MAC: 00:00:00:00:00:00
Uploading stub...
Running stub...
A fatal error occurred: Invalid head of packet (0x47)
Failed uploading: uploading error: exit status 2
Hello,
Devices with the ESP32-S3 microcontroller, like the Clockstar 2.0, do not have official Arduino IDE support.
Since both the hardware and software are open-source, you can still program the Clockstar 2.0 using another compatible Arduino board type, such as a generic ESP32-S3 dev module.
HW link: Clockstar 2.0 Build Guide
Sw link: GitHub - CircuitMess/Clockstar-v2-Firmware: Firmware for Clockstar v2 revision.
The main hardware difference from the original Clockstar is that the 2.0 uses the ESP32-S3 chip instead of the ESP32, which is why the previous Arduino software isn’t fully compatible.
We hope this helps! Please reach out if you have further questions.
Best regards,
Ana | CircuitMess
Thanks! I found a way to get micropython to have persistent programs (use ampy to upload the program as main.py on the device’s flash) but I prefer C++, so I will use this now. Thanks again!
