Artemis Smartwatch Issue
I received this watch as a gift and put it together just fine. At first, it charged well and worked perfectly. The next day, it wouldn’t turn on. The screen wouldn’t work at all. I tried charging it but when it’s plugged in the only thing that happens is the orange notification lights glow, that’s it. I’m really unsure what to do about this, I think I was sent a bad battery? I didn’t use it that much. I would appreciate a solution or maybe a new battery or watch?
Hi @Marley_Lo ,
Thanks for reaching out to us.
Could you please try unplugging the battery from the watch (the part with the red and black wires), wait about 30 seconds, and then plug it back in? That will reset the battery.
After reconnecting the battery, leave the watch on the charger for a full charge without touching it.
Also, please try restoring the firmware by connecting your device to a PC, going to https://code.circuitmess.com/ , and clicking the “Restore Firmware” button.
If this doesn’t solve the issue, please email us at contact@circuitmess.com and we’ll investigate further and make sure to sort it out for you.
Best regards,
Filip
following, as the same thing is happening with my Artemis Watch.
Hello,
Thanks for letting us know.
Please try the following steps that we mentioned earlier, and if that doesn’t help, please email us at contact@circuitmess.com so we can investigate it further and make sure to sort it out for you.
Hi, i bought the artemis watch but after programing the keyboard thing i cant seem to get back to the main home page it just turns black and sorta stops working
Hello,
Did you manage to sort this out in the end?
If the watch is still going black after coding, restoring the firmware from code.circuitmess.com is the first thing to try. If that does not bring it back, please email us at contact@circuitmess.com and we will take it from there.
