Bit stopped working
Hi from Osijek, Croatia. So I’ve bought the Bit set from the local store chain. Came Christmas day my son opened his gift, was thrilled, we assembled the kit, and in no time it stopped working. I immediately replaced the batteries and still it won’t turn on. Is there anything I can try or should I just return it to the store for a refund?
UPDATE! So after a couple hours of trying this-and-that I came to the conclusion that the source of the issue arises when micropyhton is installed on the device (as it was intended) after that, once disconnected from the USB the device stops working and doesn’t turn on at all. Once it is restored to stock firmware it turns on normally and works. What should I do?
hi i have same problem how to solve it
Same problem here, please advice.
Hello! So, I had the same problem and I managed to fix it. First what you need to do is go to “Circuitmess.com”. Then create a new sketch. For device put Bit and name it whatever you want. Put editor type on visual (it doesn’t really matter). After that connect your Bit to your PC or laptop. In top right corner you will see three dots. Press them and click “Restore stock Firmware”. Then wait a moment and your Bit will be like new. I hope i helped you. :slight_smile:
Hello! So, I had the same problem and I managed to fix it. First what you need to do is go to "Circuitmess.com”. Then create a new sketch. For device put Bit and name it whatever you want. Put editor type on visual (it doesn’t really matter). After that connect your Bit to your PC or laptop. In top right corner you will see three dots. Press them and click “Restore stock Firmware”. Then wait a moment and your Bit will be like new. I hope i helped you.
Hey @Leon_Rebernik,
thank you for sharing with the community!
If the rest of you don’t manage to solve the issue, please send us an email to contact@circuitmess.com and we’ll assist you.
Thank you!
-Monika
it keeps disconecting and conecting
Hey @marko,
We’ll send you an email to see how we can assist you in making your Bit work.
for anyone who managed to brick the Bit and have the restart (connect and disconnect) issues, just open a new sketch, click on connect in the browser, the list of the connected devices should show up.
You will see the bit jtag connecting and disconnecting after 1 second, infinitely.
The trick is to click it when it shows and immediately hit the enter key. It will start programming again as soon as it will reconnect and this way you will be able to reflash the device with micropython. You will get a stable state without disconnecting where you can continue to whatever you need to.
Hi, I restored fermware, but Bit still chrashes when I install micropython.
Hey @popa.valentin84, Bit does not crash once you install MicroPyhton. To be able to see anything on Bit once you install it, you’ll have to code something and run that code.
once i load micropython the screen stops working. I have the code for the flappy bird exactly as in your demo and it fails on the first variable definition and hangs. then the device is bricked nomatter what you try to do with it unless you reload the base firmware.
So micropython → device dark and unresponsive → load code does not work = my conclusion was micropython bricks it
thank you for your reply.
Each time you install MicroPython on your device, the device will go black - that’s how it supposed to be. Once the custom code is on you should be able to see it on your device.
Are you able to restore firmware on your device and get back to the main menu and original code?
