I can connect with the Byteboi to the computer successfully, but once I start the Micropython install it wills start the Byteboi screen blanks for about 40 seconds, then boots back into the game interface. My expectation is that with the python installed that it should remain blank? The Micropython install hangs and eventually times out and kicks back to the screen saying that it isn’t installed (Micropython).
Any thoughts on where to take this? I am stumped. I have used multiple cables. I get the same results on attempting to restore the original firmware.
I’ve been having this same issue, is there a fix yet? i keep going around in circles when contact the support team about this issue, have the same on the wheelson car
Hello Konstantin, Shawn and TJLavigne!
I have 2 sections that may resolve your problems.
Here is the 1st section:
First things first, verify that your USB connection is alright. If it is, then try a diffrent USB cable, make sure you connect DIRECTLY to the PC otherwise if you connect to a USB Hub it may not recognize it.
Second things second, check your batteries. If your batteries are dead then that can be the cause of the power off.
Third things third, disconnect your byteboi from your PC. Open a Command Prompt window and run the command: mode (it may say that you cant run the command, just run the command prompt as administrator to solve that issue) then connect your byteboi and run mode. If you see a new COM that means you are getting recognized and your browser is having some issues.
Here is the 2nd section:
Are you connecting trough a USB Hub? Just know that some hubs dont work on code.circuitmess.com and you cant flash the firmware if its connected trough a hub. Try this!
Use a different cable
Why: Sometimes a cable fails and cant work with code.circuitmess.com
Try connecting to a different USB
Why: The USB sometimes cant work with code.circuitmess.com
If you tried all my steps then wait for tommorow where you can get real professional help by the experts at Circuitmess!
I’m having the exact same issue with my ByteBoi. I’ve tried everything you suggested and more, even swapping out SD cards and doing a firmware reset, with no success. I reached out to the Circuitmess contact email about this issue around a week ago and have yet to receive a response. Do you have any ideas? Literally anything would help at this point. Thanks!
Thanks for the welcome! Circuitmess responded to my email a few days after I posted my message here. Apparently, a chip used in the code upload process was manufactured on the edge of its tolerances in the older Byteboi models. This means that some computers cannot communicate with the Byteboi while others can, since the electrical properties of USB ports vary between computers. I tried a different computer, and the issue was completely resolved!
By the way, I’ve been recently trying to figure out how to write custom games directly to the Byteboi’s micro SD card. It’s inconvenient for me to swap computers between code uploads, and I already have VSCodium and a USB to micro SD adapter. After asking Circuitmess for resources and help with this, I was told that the feature was currently unsupported but in development. I’m very impatient. Do you have any ideas?
So far, I’ve figured out how to add a new game to the Byteboi home screen with a custom game icon. I also know that the screen is displayed in RGB565, the game code is run in ESP32, and the source code was likely developed with ESP-IDF, which can be added to VSCodium as an extension. I have not yet figured out how to decompile the stock game code or write my own ESP32 code. Do you know of any information that might help?
