Hi -
My Clockstar v2 is not connecting to the CircuitMess web IDE in Chrome. It says that “No compatible device was found.”
I have used different USB-C cables and I am not using a hub. It was soldered at the factory. It is powered on.
In Arduino IDE, it shows up as /dev/cu.usbmodem101
But I would like to access it through the CircuitMess web IDE.
Here is an image of the watch:
Here is an image of the setup:
Here is an output from esptool:
esptool.py v4.11.0
Serial port /dev/cu.usbmodem101
Connecting...
Chip is ESP32-S3 (QFN56) (revision v0.2)
Features: WiFi, BLE, Embedded Flash 4MB (XMC), Embedded PSRAM 2MB (AP_3v3)
Crystal is 40MHz
USB mode: USB-Serial/JTAG
MAC: d0:cf:13:0b:04:7c
Uploading stub...
Running stub...
Stub running...
Warning: ESP32-S3 has no Chip ID. Reading MAC instead.
Hard resetting via RTS pin...
Thank you for your support!
