Codee Not Leveling Up
Hi everyone,
I’m having a serious issue with my Codee. When I opened it up, only Oil I Need was unlocked, and so that’s what I played. Finishing Oil I Need didn’t do anything even when Codee needed oil.
I noticed the GitHub was on version 2.0.1 and my Codee was on 1.0, so I tried to flash it using esptool.
After attempting to flash firmware (both stock 1.0 and latest 2.0.1), it will not power on correctly. Here’s what’s happening:
Symptoms:
  • Charge light flashes rapidly or stays off
  • Screen shows white but never boots
  • USB disconnects/reconnects repeatedly and makes noise when connected to PC
What I’ve tried so far:
  • Fully erasing and redownloading flash using esptool (just turned the screen white)
  • Using multiple USB cables and ports (didn’t help)
  • Attempting to go into bootloader mode (how does that work?)
  • Letting the device fully charge overnight
  • Restoring Firmware on code.circuitmess.com
Despite all of this, the device still won’t start.
Request:
  • Any recovery methods I can try
  • If not, instructions for a replacement
Thanks so much for any help!
Hello @icicleamazing ,
Thank you for reaching out to us and for providing such a detailed description of the issue.
We’ll check this out with our tech team and get back to you as soon as we have more information or possible next steps.
Kind regards,
Filip
Thank you for your patience.
We noticed you opened a few different threads about multiple products, so could you please email us at contact@circuitmess.com with:
  • a short summary of all issues you’re having
  • your order number(s), or your full name and surname that’s connected to your orders, so we could find them in our system.
Thanks in advance!
Kind regards,
Filip
