Display Driver for Artemis Watch (for zephyr port)
Background
I am trying to port artemis watch to zephyr and I have a good start with a bsp as a zephyr module. However, I cannot seem to get the display working. Looking through the official firmware, looks like it is using ST7735S, however, I cannot get zephyr’s display or lvgl samples to drive the display despite it building fine and other modules like uart shell etc. working fine.
Support appreciated
https://cdn.shopify.com/s/files/1/0552/3269/2430/files/Artemis_Watch_2.0_schema.pdf shows the connector for the display but not the actual driver and I was wondering if you could provide the part used and/or the data sheet to help me debug. The path that I am planning to take if this is not possible is to port over the display driver from the firmware project as a new zephry display which I would like to avoid if possible.
I plan to open source the port once/if I can get the basics working like:
  1. Display
  2. IMU
  3. BT
Thank you!
