HI all,
Thanks a lot for the cool product! We tried to follow instructions until Step 12, but unfortunately no text was displayed at that stage. After checking the debugging guidance, I did not see any obvious errors.
Here are pics of the board. Hopefully quality is good enough.
IMG_20181206_175559|666x499
Here is the another image
Hey, thank you for supporting MAKERbuino.
Can you please verify that you’ve soldered the 22pF capacitors next to the crystal?
I can’t see that numbers on the capacitors from this angle.
Yeah, the number 22 was a bit faint but from this angle you can see that it was the correct one. What could be the next step in debugging?
Continue with step 13 (soldering R3 - 10kOhm resistor) and try step 12 again
Yeah, do what @Bl4ckM4ch1n3 said and see if it helps.
If that doesn’t work, send us your MAKERbuino (only the circuit board) to:
CircuitMess,
Maksimilijana Vrhovca 11,
47000 Karlovac,
Croatia
I’ll personally fix your console and get it returned to you.
Thank you for your patience and understanding.
