When I touch Run on circuitblocks, the screen turns grey, then white and fails to run the program on my Ringo. It also stops working until I re flash factory firmware
Hey @Chillinger,
thank you for reaching out.
You can’t have both the stock firmware and Micropython installed on your device at the same time. This means that you will have to click on the “Restore firmware” button if you want to put the stock firmware back onto your device when you’re done with using your own coding examples.
Regarding the screen, please send us a bug report through CircuitBlocks so that we can review your code and help you solve the issue.
Sandi
I found a way to fix it.
I didn’t realise that I had to push the frame every single time.
Hey @Chillinger,
thank you for letting us know, and congrats on making it work on your own!
Feel free to reach out at contact@circuitmess.com if you have any other questions ![]()
Sandi
