how can I change my bit to the original theme and menu? I want the classic one.
Hello @Serafinos_Ksinos,
Thanks for reaching out.
If you want to put stock firmware back onto your Bit, connect your Bit to your PC with a USB cable (make sure it supports data transfer), then go here: https://code.circuitmess.com/ and click on the Restore Firmware in the upper right corner.
If you have any other questions, feel free to reach out to us.
Best regards,
Filip
