I am making a game and i want to create a menu with some options when i press C button, but gamebuino wiki instructions are not clear to me. Can someone please help me with making menu.
Second question: how to add sprites? I know that you need to add bitmap but gamebuino wiki only says how to add it in game, but how to create it(bitmap)?
Thank you
Hey Leo,
There are multiple approaches you can take to create a menu in your game. In one of my games (Video Poker), if the C button is pressed it will call a pause menu function which contains its own infinite loop:
// Button C - Pause Game
if(gb.buttons.pressed(BTN_C))
playSound(sndPause, 0);
pauseGame();
The pause function is as follows:
// Show pause menu
void pauseGame()
while(1)
if(gb.update())
gb.display.cursorY = 18;
gb.display.cursorX = 20;
gb.display.println(F("P A U S E D"));
gb.display.cursorY = 30;
gb.display.println(F("A: Title Screen"));
gb.display.println(F("B: Show Hand Info"));
gb.display.println(F("C: Resume Game"));
// Button A - Return to Title Screen
if(gb.buttons.pressed(BTN_A))
setup();
return;
// Button C - Resume Game
playSound(sndResume, 0);
return;
// Button B - Show Hand Info
if(gb.buttons.pressed(BTN_B))
showHandInfo();
The source code is available here if you want to check it out:
https://github.com/delpozzo/videopoker-gamebuino/blob/master/src/VideoPoker/VideoPoker.ino
Regarding your second question about the sprites, if I remember correctly you can use the Bitmap Encoder utility located here to convert them to code:
http://legacy.gamebuino.com/wiki/index.php?title=Download
