I tried to download the software to add games and now my byte boi won’t turn on
Went to the website from the packet and connected my btye bio to my of. I had been turning on and it was on when the download started. It was randomly turned off halfway through and the download had an error. It won’t run on anymore. I think the software name was micro python or something like that. Anyone know what’s happening or how to fix it?
Hey @TheJester,
please try restoring firmware on your ByteBoi (once again connect it to the PC, turn it on, and click on the Restore firmware button in the upper right corner). Let me know if this returned you to the main menu of your ByteBoi?
After that you can try installing MicroPython again.
I have the exact same problem and the ByteBoi will not connect to the PC. Is there an option to hard reset?
Hi Finley!
First things first, verify that your USB connection is alright. If it is, then try a diffrent USB cable, make sure you connect DIRECTLY to the PC otherwise if you connect to a USB Hub it may not recognize it.
Second things second, check your batteries. If your batteries are dead then that can be the cause of the power off.
Third things third, disconnect your byteboi from your PC. Open a Command Prompt window and run the command: mode (it may say that you cant run the command, just run the command prompt as administrator to solve that issue) then connect your byteboi and run mode. If you see a new COM that means you are getting recognized and your browser is having some issues.
Feel free to reply if you followed all the steps and still cant get it working.
Regards,
Petar
