The screen is powered too, there 4,2 V between GND and VCC pins of the screen. Screen backlight is working and could be pretty bright, but no any picture on it.
ATmega is well powered. There are 3,2 V between 1,8; 7,8; 22,21; 22,20 pins. There are only one picture, but trust me, all pins are powered as it should.
So, it should be working, but does not work. Could the ATmega chip be damaged? There are no any visible marks and I used anti-statik wirstband during work.
Hi, I had the same problem. I got a blank microcontroller, check if the Arduino IDE recognize your Makerbuino (select Arduino Uno, choose the right serial port and try to upload a sketch).
If the Arduino IDE doesn’t regocnise the Makerbuino and everything soldered correctly, then you probably got also a blank MCU and you should write an email to support. (Or you try this: ATmega328 without firmware [SOLVED])
