i have had my makerbuino for a couple of days now and all of a sudden it stops workind
please can i have some help?
ive got some pictures here if it would help
Did you turn it off whilst a game was loading? I’ve not built mine yet but was just reading the assembly etc and on chapter 4 it has the instructions below. Might be worth a try otherwise if you explain when and how this happened and if it was working before then someone might be able to help you.
IMPORTANT
If you turn your MAKERbuino OFF while a game is loading, its memory might be left blank and you’ll get a white screen.
Fortunately, this can be fixed quite easily.
You will have to do the C-button reset trick like this:
- insert the SD card
- turn the console OFF
- hold the C button
- turn the console ON
- release the C button
- wait for 30 seconds
The SD card loader menu should appear
@YoshiK1, thank you for help out, this is exactly what I was going to say
I can see that @loverugby managed to solve the issue by finding the answer in another thread:
Hence, I’ll mark the topic as solved.
See you folks around on the forum!
