@jagjot, thank you for supporting MAKERbuino and I am sorry for the problems that you’re experiencing.
Can you please open a new topic for your problem?
Also, the problem that you’re experiencing is most likely caused by a bad connection between the charging board and the battery. Can you please examine that and see if there are any soldering points that could be improved?
Also, can you please elaborate on the problem with the casing attachment that you’re having? What do you mean by the “nuts were too small”?
fixed the nut problem and i think the problem might be the battery because when i unplug the charger there is no sign of battery life
Thanks, I’ll answer here:
