Hello, I have just completed the nibble project (great fun by the way!) and it was working fine, I had just put some new batteries in and decided to try circuit blocks.
I then, because I can, connected the nibble and tried the ‘Restore Firmware’ button. This all went OK it seemed but now, even with new batteries, I get ‘battery level too low shutting down now’ and cannot seem to get past this.
I saw that there was some similar problem in the makerbuino section but the resolution made no sense in this context. I.e. in CB interface (I use Linux) I only have the option to start a new project or ‘restore firmware’.
Albert, thank you. Just so you know, I can still upload and run the CB examples in the lessons. They all work while I am connected via the USB B cable But it’d be cool to be able to restore the nibble back to the default games/settings etc.
Hello, pkx. My apologies for the long wait. From the description of your issue, it seems like the internal ADC that measures the battery’s voltage level might be malfunctioning. Please contact us at contact@circuitmess.com and I’ll get in touch with you so we can resolve the problem if it’s a software issue, or send you a replacement if it turns out the ADC really is bad.
